Trifecta Performance Tune
dracy69
So I ordered a programmer for the Regal Turbo from Trifecta Performance. Vince (Trifecta owner) just bought a Regal for himself and is doing some work.
Mine just showed up in the mail today, I will have it installed this week and will definitely update you guys on the changes. The tune is 350-550 dollars depending on if you want to keep the cable for it.
trifectaperformance.com
Yes please do!
vince said he got 50 more hp and about 52 moe torque..
saving my pennies for this.
Those are awesome gains! Are those results with no mods??
Edit: n/m i see "stock vs tuned"
Thats excellent! Im still waiting it out before i unleash what my Lacrosse is capable of. I would hate for my tranny to crap on me afterwards.
Awesome - I have been following their front page for a few months now! Maybe they can setup a group buy discount for the Buick forum?
I would not expect to see major gains from the 3.6L. Forced induction engines is where you see the biggest gains.
Does this program still allow you to switch between E85 and standard premium fuel?
I understand that. I didnt mean i would see big numbers like the turbo regal. But the fact that the Lacrosse and the Cadillac CTS use the same engine. The Lacrosse is clearly detuned and with some adjustments can open her up. Ive been watching Trifecta for years even before my Lacrosse, and they seem to have a good quality product.
Good point!
Have there been any independent tests done to verify Trifectas claims? Or is that what Dynojet does?
nope my car is going to the dealer monday so I will have this tune installed monday night.
and then it will be update galore
vince told me the tune is getting updated this week, he is probably working on the cruise control switch. cruise control switch one, tune on, switch off, stock programming.
that would be a fantastic update...
Why not use the "Sport" mode to switch the tune on / off?
because not all Regals have IDCS
Ok, so I have the drivers installed on my laptop, I have the EZ Flash software ready to go, waiting on the actual tune file. The process is a little more complicated than your average tuner so I didn't know I needed it till now. It's 6:40PM here on LI so it should be more like 2:40 or 3:40 in Washington state where Vince is so hopefully he can get me my tune file tonight and I can tell you guys how it goes
man thought everything was ready to go already..
That would be so awesome.
Good luck :headbang:
growing pains for the first tune?????
OK, so far...the car is MUCH faster. Like I uninstalled it today (more on that soon) and I'm honestly having withdrawals....
Throttle response is much much much much much MUCH better, and frankly the car pulls pretty hard through second gear....but the trouble starts here, when you enter 3rd gear.
The car slips.....pauses.....then SLAMS into 3rd. I have had experience with tuning diesel trucks, my mom's G8 has torque management taken out of the tranny and some other performance goodies, I had an Impala SS with a programmer and firm shifts, they all pale in comparison to the jerk this made.
This only happens at 75% throttle and up (roughly). In all IDCS settings (which has been cooperating with the tune so far). Drive the car normal and it feels normal.
I decided to let it be for the night, drive it work in the morning and see how it goes.
The drive to work, was simply awesome. I gradually laid into the car, in small increments. Half throttle for a few miles here, a little bit more when I make it to nichols rd, a little bit more when I make it to sunrise hwy, basically giving the tranny a chance to get used to it. After about a half hour I was confident enough to do some full throttle runs from 30 and boy oh boy did the car reward me with great power and smooth shifts. It's crazy how well it pulled at 70mph.
I e-mailed Vince about the shifts anyway, he said it has been an issue (intermittently) with the cars he has tuned so far. The explanation is the transmission module is deciding that the car is receiving too much power and cutting the throttle....in the middle of the gear and at other unusual points. Making ti feel like the car is shifting and causing it to shift badly when it does. This is most apparent at the 2-3 shift because you're usually not at full throttle for the other shifts.
This problem came back at lunch, either from the shorter run time or from the heat (100 degrees!) and 5 minutes into my drive home my check engine light came on.
Uh oh.
I called OnStar, they said "It is an engine/transmission code, the turbo has performed unexpectedly". Well that is vague. I pulled into a gas station and switched the car back to stock and told Vince about it, he said it is likely an underboost code. Another customer got one (his car hasn't). This is most likely thanks to the torque management issue, the TCM is requesting a cut in throttle and opens the bypass valve when the ECM is still asking for 20 pounds of boost. Hence underboost.
He has a solution running in the car for the torque management but is waiting a few more days to send it out to make sure he has that bug ironed out.
I'll update you guys when that happens.
