fm9572
- Oct 10, 2013
- North Carolina
- 1994 Buick Park Avenue
My 1994 base model has 157k miles on it, and started having problems with the transmission around 135k. At the time, I thought it was engine problems, because of the way it acted. But between trying a bunch of parts swapping with the engine that didn't help the problem, and tons of research, I think I've stumbled (pun not intended) on a solution.
I started noticing the problem on a vacation trip to the Blue Ridge Mountains. It acted like it had no power, and I would have to manually downshift to lower gears to keep my speed up. After I got back home, it still had a noticeable problem. I would drive about 40 miles each direction on rural highways to visit my parents every weekend. I used my cruise control to save gas, and stayed around 55mph because the highway patrol loves that route. The problem I was having was that the engine settles in at about 1500 rpm around 55 mph on level ground. if there is any slight grade, the transmission is supposed to disengage from overdrive and let the rpm go up slightly, but it wouldn't. I thought it was problem with the engine because it felt like a motor mount was broke, and the engine would vibrate and shake. This was from lugging. I would blip the throttle, and it would temporarily kick the trans back to 3rd.
After replacing spark plugs, wires, O2 sensor, MAP sensor, crank trigger sensor, etc, hoping this would give the engine more power, and none of it working, I started hitting the forums. Turns out this is a common problem with these vehicles. It seems to start around 100k-150k miles. I've read of people replacing torque converters, and whole transmissions.
Before you do all of that work, try this. GM has replaced Dexron III transmission fluid with Dexron VI. They did this in 2006. I haven't really noticed it as commercially available until the other day. My transmission was about a pint low when I was at the parts store. I tried the Dexron VI because it was 'backwards compatible.' I didn't really think anything of it. A few days later, I made a 100 mile round trip, and on the way home, it started actually shifting somewhat normally. It wasn't perfect, but it was better. This got me wondering, so I did some research on Dexron VI. Turns out, that it's a much better fluid than Dexron III was. It was used in the 4t65e that replaced the 4t60e. I had the transmission flushed right around the time I started having my problems, and I started theorizing this may have been part of my problem.
This is the info I have on Dexron VI vs Dexron III ; http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=526448#Post526448
Yesterday, I got 8 quarts of Dexron VI, and a new filter, and today, I did a fluid change. I pulled the pan, and it was full of sediment. I cleaned the pan. I used dish detergent and water. I didn't use cleaning fluid because of the possibility of contamination. I pulled the old filter off, and it was coated with the same sediment. I put a new filter in, and after I made sure the pan was spotless and dry, I re-installed the pan. I added about 4 quarts of Dexron VI to fill the pan, before I cranked the engine. I started it up, and with my foot on the brake, I cycled through the gears a couple of times. I left it running, and rechecked the dipstick. It was at the bottom. I wound up adding a total of 7 1/2 quarts to fill it back to the top.
I did a test drive after a cleaned up, and put away my tools. I had to go to the parts store to get a radiator petcock to fix a leak, and had to dump the fluid and oil from an earlier oil change, so it I made good use of my trip to town. I kept tabs of how it drove. I noticed that it accelerated more smoothly, it seemed to shift much more freely, and it didn't lug and vibrate when it was in cruise control. I don't know if this is going to last forever, but it seems to work fine for now. I've always heard the old wive's tale about not replacing the filter, or cleaning the pan, but I think that's a bunch of crap, personally.
I can't say this will work for everyone, but it worked for me. I would definitely give this a try before I invested $1500 in a new transmission. It was $50 for the fluid, and $25 for the filter and gasket. I would up using the factory gasket, because it was one of those rubber coated metal 'reusable' ones that was better than the cork gasket that came with with filter.
If your transmission is having overdrive problems, or is shifting funky, I'd try this before I sunk some serious money into it.
If someone else tries this, please let me know your results.
