LadySmith
- Sep 2, 2008
- Alabama
- 1995 Buick Park Avenue
I have a 1995 Buick Park Avenue. It will just randomly go dead. You never know when it's gonna do it. It could be while you're at a red light or stop sign or while you're slowing down to come to a red light or whatever. But, it can also happen when you're going 65 mph down the road. There's no pattern at all; when it decides to do it, it just does it.
When it does go dead, sometimes you can put it in neutral and it will crank right up..no problems. Other times, it will not crank. Then, after it sits a little while, it will finally crank up.
This can happen at any time. You could drive a 45 min. drive and it not go dead at all. Other times, you could only make a 15 min. trip to the store and it will go dead 3 times. Just whenever it decides to.
A few weeks ago, I ended up being stranded and had to be towed. Anti-freeze got into the oil. That ended up being the intake manifold. After that was replaced, along with an oil/filter change, the car is still having the going dead problem. So, evidently, that intake manifold was just a coincidence and totally unrelated.
The check engine light is NOT on. There are no codes.
My husband replaced the fuel pump and fuel filter and it is still having the same problem.
We know that now it must be in the electronic system...some sort of sensor or relay or module, but have no idea which one since the check engine light isn't on.
Where do we start? We're thinking maybe to start with the fuel pump relay, but don't even know where it is located. We see the fuses and relays under the hood, but don't know what relay controls what.
Also, we hate to replace that if that's not going to fix it. How can we figure out what it is without spending a fortune on all those sensors, relays, modules or whatever?
Any help is greatly appreciated!!!
Also, any help finding wiring diagrams and such for this would be a big help.
