95 Buick Roadmaster Door Panel
Boss
I just pulled the door strap away from the door panel on my 95 Roadmaster. It came lose at the back end of the handel strap. I can see a larg pointed sheet metal screw and some clips to hold the plastic trim in place.
I can't figure out how to get at that screw so I can tighten it.
Has anyone run into this problem? I would appreciate some help on this problem.
Thanks guys.
It's difficult to decipher what you're getting at in your post. Pictures would really help. But big sheet metal screw, and door strap, from that i have to ask. Are you aware that either end of the "door handle" strap pull up to show the large Phillips screw on either end? There are some other screws holding the panel on separate from the door handle parts that come off first.
Dont be hatin'! The buicks dont have all that noise dampening awesomeness, vibration isolated bose speakers, or fancy pull cord actuated self-destructing window actuators.
<< owns a 2001 Deville.
What you say is true, i'm just kiddin around.
