Resetting Buick Oil Service Indicator Lights.........
98 TWILIGHT BLUE METALLIC
4.6L Northstar Member
Buick LeSabre, Park Avenue, 2000-05
Turn the ignition to ON. Press the GAGE INFO button on the driver information center (DIG) switch to view OIL LIFE INDEX. Press and hold the RESET button on the DIG until the display reads OIL LIFE INDEX 100% NORMAL. The engine oil life monitor is now reset.. Turn the ignition OFF.
Buick Terraza, 2005-06 Buick Park Avenue, 1997-99
When OIL LIGHT INDEX CHANGE OIL appears in the Driver Information Center, press and hold the RESET or TRIP RESET button while the oil life index is being displayed. After 5 seconds, the oil life will change to 100%.
Buick Le Sabre, 1995-99; Buick Park Avenue, 1995-96
When “CHANGE OIL SOON” light is illuminated, access the reset button in the glove box. With the engine off, and the ignition switch in the RUN position, press and hold the button for at least 5 seconds. The light will flash four times then go out.
Buick Allure Buick Lacrosse, 2005-06 Buick Century, 1997-05 Buick Regal, 1996-04 Buick Roadmaster, 1995-96
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds.
If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on for five seconds, repeat the procedure.
Buick Rainier 2004-06, Buick Rendezvous 2002-05 w/o (DIC) Driver Information Center
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three time in five seconds. If the CHANGE OIL SOON’ indicator flashes two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on for five seconds, repeat the procedure.
Buick Rainier 2004-05 wI (DIC) Driver Information Center
The DIC display is located on the instrument panel cluster above the steering wheel. The DIG buttons are located on the steering wheel. Press button with the gas pump symbol to display engine oil life. Press button with the arrow symbol to reset engine oil life display.
Buick Rendezvous 2002-06 wI (DIC) Driver Information Center
To reset Service Reminder Indicator, turn ignition on with engine not running. Press the MODE button until DIC reads oil life left hold SET to reset. Press and hold the SET button until 100% is displayed. You will hear three chimes and the change oil message will go out. If the CHANGE ENGINE OIL’ message comes back on when the vehicle is started, the engine oil life system has not reset. Repeat the procedure.
Buick Roadmaster, 1994
To reset the “CHANGE OIL” light, turn the ignition switch to the RUN position with the engine off. Access the reset button on the end of the instrument panel by the fuse block. Press the switch and hold it for at least 5 seconds.
Buick Le Sabre, 1992-94; Buick Park Avenue, 1991-94
When “CHANGE OIL SOON” light is illuminated, find hole in undetside of dash on passenger side near door. Insert a pencil or other blunt instrument into hole and press switch. The light will flash four times when the system is reset.
