CarDude225
- Apr 20, 2015
- Buick
95 LeSabre / 99,500mi
I thought I would just offer an informative post, since I found very little information on the subject.
I was alerted by my wife driving the LeSabre that it smelled like gas. Parking the car, shutting it off, and looking under the hood, gas was spraying out of the main 3/8in line supplying the fuel rail. The stream of spray was toward the firewall in the vicinity of the blower motor, and above the hot exhaust manifold. The spraying continued for a number of minutes until the pressure in the fuel system was relieved.
This was very alarming to me.
As a temporary repair, on site I treated the leak area with epoxy. Eventually I deemed it safe enough to drive home. Over the next few days I applied up to 5 total coats of epoxy.
Note: After a few days, it began leaking as the epoxy was lifting off of the nylon tube. As an emergency measure, I did the standard "wrap-and-clamp" with rubber which held well for a day until I did the following:
I found in stock at Advance Auto Parts a brand "Needy" #800-059 3/8in rail connector right-angle to a few inches of nylon tube to a barbed coupler. Do not confuse this part number with brand "Dorman" #800-059 (which probably would have worked just as well). This was $20 (overpriced, but cheaper than replacing a burned up car). I installed this last night. Dealing with fuel, I was not terribly impressed with the way this re-designed quick connector was secured to the fuel rail, so I added 2 zip ties to help keep the connector on the rail. I also used my own screw-clamp at the far end to secure the car's nylon line to the barb. I then used electrical tape to wrap the metal clamps and barb, in effort to insulate them from heat, thinking that the searing hot heat that exists in these engine compartments may cause the metal in the fuel lines to alter the nylon fuel lines causing another leak. I really don't want to play around with FUEL, especially while my girls are driving that car.
Epoxied Repair
I consider this permanently repaired now. I will reply to this post with updates if there are any further problems regarding this repair.
Epoxied Repair
