saleen90181
- Jan 27, 2016
- Central NJ
- Buick - 2016 AWD Turbo
Its a total engine fail due to a know issue (Cadi guys know the issue )- car is down for at least a month in my PO
I have an issue - car didn't make it off the lot when i bought it - failed PS rack
Then failed again PS rack - recall - down a week
Then Failed again - sensors - power - ECU
Failed 4 times with right front tire pressure - the wheel is cracked but they wont admit it
Looking to lemon law it I think
A car with less then 6000 miles on it - did not make if off the lot the day it was bought - has 4 document times that the front tire and suspension has an issue, reported motor power issues in last service, and now has launched entire motor - cly 2 at least and 4 has a major issue
SO GM is aware of this issue - Caddie guys complaining to GM - i am sure more Buick will add in the future
Not a lot of Buick guys have a AWD Turbo 2015/2016 2.0T - not a lot sold - and GM wont give us production numbers
i hope GM/Buick/GM sees this- but here is a vid
it's extremely common on the 2.0T, total stock long block - heads, upper and lower, injectors, heads, exhaust, turbo, inter cooler, so on - even running 92 gas
[url]http://www.cadillacforums.com/forums/cadillac-ats-performance-forum/613529-2-0t-bad-pistons-roll-call.html
[/URL]
Its stock - it has the stock upper/lower intake manifolds - stock MAF -stock Throttle body - stock heads - stock injectors - stock trans - stock heads - stock Turbo - its the same as the Caddie ATS - same heads - same stock exhaust - same config
https://youtu.be/V2VFH9_3hcA
Its at the dealer - its blown up that they told me - replacement motor requested
I might have to rethink keeping the GM and going back to Ford
[/URL]
