IMSITINGINYOURCHAIR
- Apr 20, 2012
- northeast Alabama, USA
- 2k lesabre custom (sold) 2k lesabre Limited (sold) 02 LeSabre Custom 220k(sold)
As requested, here is the process I used to repair the drivers side seat bottom heat element. Click the links for a picture to help guide the process.
**I am not responsible for any burns or resulting damage as a result of this repair method It is your responsibility to ensure any new connections you make are securely connected.**
Step one. Raise the seat bottom as far up as it will allow.
Step Two. Remove the seat adjustment buttons and lumbar support knob* (if equipped)
up/dn fw/bw switch: pry from right side then remove by hand
seat back fw/bw: pry from top then remove by hand.
lumbar support knob: pry from behind the exposed yellow slots
Step Three: Remove the seat cover
Start by releasing the clip under the seat pull down and twist clockwise relative to the side of the car.
There is another clip to the left of it. the seat should come up like this
Step four: Separate the leather cover from the cushion. You will be greeted by an orange cloth held to the seat by velcro. separate it from the foam.
Step five. I didn't really get a good picture of this part as i had already preformed the repair.. the burn mark you see here is a result of a bad connection after i first tried the repair. I tried soldering but i couldn't make the solder flow into this wire, I eventually tied a knot in it then wrapped that with solder wire to help carry current and prevent a hot spot in the seat, it also helps in safety. if the wire gets too hot from the connection working loose, it will melt the solder and re secure itself. It is important to make sure you have a secure connection to prevent burns or hot spots** in the seat.
On an unaltered seat, the elements are under some foam on the cover of the seat. they're made of uninsulated aluminum wire laid out in a zig zag pattern and glued to the top portion of the seat. I started a tear from the power inputs and worked my way across where I found the broken element sections. After you fix any breaks check for continuity across each wire until you have an open section, fix any breaks checking that the seat heats each time. To check that the seat works, turn the key on then press the heated seat button. one click is on. two clicks is a fault (relay on, then off)
Once you have the connections repaired and have verified that the heated seat is working, turn it to high then watch your connections for smoke. this will help prevent any burns/other damage. repair as necessary then re assemble in reverse order.
**hot spot: increased resistance caused by a loose/bad connection that causes higher heat in that area. this can cause the foam to melt or burn through the seat. If you notice a section is uncomfortable use only on low until you can go back ad re check the connection.
