180 on the speedometer is to allow for the easy MPH->KPH switch as this car is a pretty global platform and only two of the markets it is sold in are MPH.
I do not know the reason for the 180mph speedometer scale, but per below it is not for MPH/kph reasons
https://www.vauxhall.co.uk/content/dam/vauxhall/Home/brochure-library/cars/insignia/price-guide.pdf
Holden Commodore RS-V Sportwagon 2019 | Holden Australia
Insignia Country Tourer
Insignia Country Tourer | Echter Offroader | Opel Deutschland
0-60 without flashing the torque converter or spooling the turbo requires 7-1/2 second.
Practical top speed is 130 mph, and you will need about a mile plus of straight, unless you have the Bonneville salt flats at your disposal and wish to risk burning a valve or piston. There are a few interstates in the US that resemble the autobahn, however your state police and insurance company would disagree. There is only so much a production 2 liter engine with out extra cooling and lubrication is capable of.
155 mph governed top speed may be incorrect if tires are not speed rated for +155 mph. Lawyer make sure of that, thankfully.
My sort of fast car develops about 600 RWHP, i.e. 400 more than a stock TourX has for WHP. For you average weight car to have any pick-up over 100 mph, you need around 500hp.
With that kind of oomph, 130 mph comes up quick, 140 is no sweat, like accelerating for 70-80 mph, in a Regal/Tourx. The acceleration pace slows down after 140, and I have no clue what happens much after that, nor do I care to find out. Unless you are in a hyper-car or a at least a super-car that is very aerodynamic, and actually built to operate at these speeds this holds true. Also the brakes on a Regal are good for 1-2 slow downs from 120 or so. Then they are then done and so are you.
Don't try this at home.
P..S. Trifecta told me they will have a tune available this summer. Example results of similar dyno chart attached. You might be able to buy a very nice wagon in America with an America engine that with just a tune could run 14 flat @ 100 mph in the 1/4 mile. What more could the mid middle class want?
Edit:
I did a little research, Seems Like V rated tires, so TourX must be governed to 149MPH or less. Plenty
https://www.tirerack.com/tires/tire...idewall=Blackwall&partnum=35VR8PCTX&tab=Sizes
The OEM Continental ProContact Tx tires are rated "meh", at best from reading the Tire Rack reviews.
Apparently the quieting belt inside the tires do not stay put.
I suggest replacing OEM tires with Extreme Contact Sports. They are soft and barely a Max Performance Summer tire, but it is an excellent high performance premium Grand Touring tire, perfect for the likes of the TourX. Extreme Contact Sports are a summer tire and will only last 30-35 thousand miles, but they will be happy miles.. Get snow tires for the winter.
