Oliver H
- Aug 30, 2019
- 2016 Cascada
How to clean out the clogged rain water drains located in the right-rear and left-wheel wells.
1) remove left rear wheel.
2) partially remove wheel well liner (rear fender liner).
3) locate 1/4" drain hole, and clean out with a pipe cleaner or small screw driver.
(Rain Water trapped inside )
Repeat the same process for right side.
SYMPTOMS:
- hear water sloshing around when going over speed bumps or driving on bumpy roads at slower speeds.
- wet carpet behind driver or passenger seat floor (rear carpet).
- rain water dripping near rear wheel well....for serveral hours, after rain has stopped.
There are (2) rain water drains that get clogged up that need to be cleaned out occasionally. In NC, I get the long pine needles which get inside a hollow body area......that rain water get inside and that has a drain to let the rain water out.
See:
PIMPmyCASCADA
there are pictures at this link which show the steps.
There is no mention about this in the Cascada owner's manual.
You should not hear any water sloshing sounds....... inside the Cascada passenger cabin, ever.
SYMPTOMS:
See:
PIMPmyCASCADA
