ParkAveCore
- Jul 31, 2022
- 2005 Buick Park Avenue
Thanks sooo much for the detailed reply. I just got the car today and while I looked over it for about two hours, IView attachment 38737View attachment 38736View attachment 38739View attachment 38738
does your temp readout(digital) kinda jive with mine here? The car SHOULD be able to get that far with a needle, the ones in mine have to be understood as not straight on shots, so they are more to the right of center than youd realize. To me, sounds like cap, thermostat, plugged line between reservoir and radiator, and condition of coolant should be inspected.
See the orange fanta? Dex cool when nice and clean mmmmmm thats what you want to see not the previous pic(water and the scale that existed in there for years)
Something to note is the readout on the IPC And the gauge will both not match the live data of a scan tool
A scan tool will likely go to higher numbers amd change all the time. Thats intentioned to make the cluster "smooth" it out since it only
Oh its precise. ish. the upper temp range the resistance values get some wider gaps just llike when really cold. the max temp, or close
Does your car have a IPC with the slew of buttons on the left side or do you have only 2 buttons? to the left of the IPC that is.
I only have the two buttonsView attachment 38737View attachment 38736View attachment 38739View attachment 38738
thanks sooooo much for the detailed reply. Look at that fuel economy and low rpm’s! Love these cars. I wish I had the digital coolant temp readout!View attachment 38737View attachment 38736View attachment 38739View attachment 38738
