greatcars
- Apr 22, 2014
- Buick
Hey everyone, new to the forum so thanks for any help you may be able to provide. I know all about the typical abs/AWD disable light, the wires to the sensors being to short and all that jazz. This is NOT that issues. All wires have been checked and are fine and I do not get the AWD/Disable light. There are no codes stored in the Electronic Brake Control Module and all speed sensors are giving accurate readings (within 1 mph).
Both front hub assemblies with speed sensors have been replaced within the last 10k miles.
The issue that I'm having is that when coming to a stop the ABS will engage, not every time, and not specific to any event (i.e. turning the wheel when stopping, slamming on the brakes, etc.) The only common trait when it occurs is the vehicle is less than 10 mph. It never engages at highway speeds or anything else. I have an Autel Maxidas DS708 scan tool and have hooked it up and am getting nothing out of the ordinary. It does show that the abs is engaging when the problem happens but it's not giving me any indication of why and all other parameters are showing normal.
Any Ideas??? If your familiar with my scan tool and have any suggestions on tests or things I should be looking it would be helpful as well, I just bought the scan tool a couple weeks ago so I'm not an expert with it by any means.
I've read about the flow valve in the rear transfer case but I don't believe that is the issue because everything I have read says that the AWD/Disable light will come on and you will get codes from that being clogged.
I've also checked the connections under the car by the drivers seat, pulled them apart and looked for corrosion. There was no corrosion and I put some dielectric grease on them and put it back together, still getting the issue.
