04 lesabre door problems
brandonfleming202
04 lesabre
alright I'm new on here. ive got an 04 lesabre I'm troubleshooting. when you open the driver door the radio does not shut off and dome light does not work. but the door ajar light does work. also i noticed the security light that is supposed to flash on the dash, does not flash when opening that door. any suggestions would be great. im thinking at this point its the door control module behind that driver door panel
solved it. turns out its the door lock mechanism itself. its worn to the point that opening and closing the door does not work, But i can engage the turning piece with my finger easy peasy.
alright so ive been working on this for days.. the door lock mechanism went bad, so i removed the old one. the car was running fine with that removed, until i hit the button to turn off the headlights.. the car shut off and lost all power to the ignition and blew the ignition fuse.
Today i installed the door parts and put it all as it should be, now i have no power to the ignition and no lights on the dash. also the car starts now by inserting and removing the ignition fuse, without any key at all... please can someone shed some light on this????
That's crazy. I hope someone here will help you
