FiftysLost
- Jan 4, 2011
- Illinois
- Buick 2021 Encore GX Select
Hi all.
I have a GPS that I will put on the dash using the Garmin Bean Bag. I didn't like the idea of running the wire down the dash and the center console to the outlet in the storage compartment. I found the outlet at Walmart for $10. I'll show this one http://www.acehardware.com/product/index.jsp?productId=2459115&cp=2568443.2568455.262 9363.1258923 so you get a better look at it. It has 2 screw holes for mounting under dash and comes with 3m tape if you'd rather. I used the screws. I removed the existing screw under the dash (just left of the console) and drilled a 1/8 pilot hole into the plastic for the left hand hole. I had to open the holes in the adapter to allow for bigger screws. This position clears the air ducts. The hook-up was a short run to the fuse box where I used a "Mini Add-A-Line" which I got at Advance Auto like this one http://cgi.ebay.com/Lot-3-ATM-Mini-A...item255968b0cc hope this helps someone.
