210010243
- Jul 5, 2010
- Buick
There are several threads here that cover a part of this message; However I will continue with my problem.
The driver's side HVAC Blows warm/cool air while the passenger side.
I have removed the Blend door actuator and moved the door by hand. In one direction it provides Hot air and in the other warm/cool.
I have removed, cleaned out the Cabin Air Filters/housing and removed the Blower Motor and cleaned that area also.
The coolant charge is correct.
Through the use of a Boroscope/Camera my mechanic has looked into the ducs searching for any obstructions and have found none,
At this point we are at a lost as to what can be wrong and before we tear the dash apart to remove the HVAC unit, I am asking for your assistance, if any of you have had an issue such as this.
