Uluz2a6
- Jun 26, 2016
- Buick
Hello from Las Vegas. Hoping to gain some knowledge from this community.
I service and rebuild GM engines and have been getting a lot of the 2.0 LTG vehicles with melted pistons. Since October I have done 5 full rebuilds. 2 Regal and 3 Malibu. All had same failure, melted piston. 3 had failure on cylinder #3 and 2 on #1.
Upon tear down I found all of them timing chains in excellent condition (unlike all the 2.4 DI engines), no sludge or deposits in valve cover or oil pan, remaining 3 pistons all looked good and rings not seized, and only DTC present was misfire on failed cylinder.
All engines had oil present throughout charged air side of turbo (turbo output, intercooler, intercooler tubes). Is this failed/failing PCV system causing the engine failures or a coincidence?
If the owners are to be believed, they claim no symptoms until a horrible misfire. Obviously too late then.
I get several Equinox and Terrains that need maintenance and able to council owners about the oil consumption issue and how to deal with it. But I don't get the 2.0 Malibu or Regal until after the failure.
Anyone experienced this? Any way to see the failure coming? Is the key just servicing/replacing the PCV system?
