Oldsmobuick
- Aug 21, 2024
- 2001 lesabre
There are 2 overhead console lights and 2 rear map lights in headliner. They all work (though drivers side console switch is intermittent)with their independent switches.
The lights that should come on when door is open have never worked.
I did replace a broken door handle.
I used attached elec diagram for reference. It is a 2006 cx i think and mine is a 2007 cxl. My assumption is they hopefully are the same.
Recently, I tested with multimeter the drivers door latch and could not get voltage signal on the 3 wires corresponding to opened/closed, or ajar when mechanically opening, closing and leaving door ajar.
The lock/unlock function works fine.
I replaced with nee drivers door latch assembly and still no interior lights.
I dont know but assume the potentiometer that brightens or dims the dash lights would turn on the interior lights when turned all the way to the right. It does not.
I have read that there is a door open or ajar notification in instrument cluster but havent seen it illuminated. Don’t know if my car has that function.
Any ideas?
Thanks in advance.
Recently, I tested with multimeter the drivers door latch and could not get voltage signal on the 3 wires corresponding to opened/closed, or ajar when mechanically opening, closing and leaving door ajar.The lock/unlock function works fine.
Any ideas?
Thanks in advance.
