2013 2.0 Low Oil Pressure Switch
LINY
This switch is leaking, it looks like it's held in with a Big E Clip. Is this replaceable without dropping
the oil pan?
the oil pan?
Everything I see online shows it is located right above the starter, remove the harness connector and use a socket.
Did you look at YouTube videos?
I haven't found a You Tube video on it. It doesn't look like its screwed in, but held on with a big E Clip.
Are you sure it's a pressure switch and not a low oil Level switch?
You are correct It's the Low Oil switch.
Unfortunately to correctly repair it you would have to drop the pan. I suppose you can try to clean the area and apply some RTV
