richardnewton
- Jul 20, 2017
- 2013 Buick LaCrosse 2.4 eAssist hybrid
I would go back to the garage ASAP as you don't want a safety issue.
It seems the 2.4L engines can go through high pressure fuel pumps & VVT solenoids pretty quickly. We recently replaced all 3. Make sure you use only OEM parts because these are so critical and rely on precise engineering & manufacturing.
- Remove the oil dipstick; check to see if it smells like gasoline; it should smell slightly like oil, not gasoline. If you smell gas in the oil, then you my have a failing high pressure fuel pump.
- The VVT solenoids are fragile. The intake solenoid can cause rough running and stalling. The solenoids can cause fuel and oil consumption too. For the 2.4L, these solenoids are replaced in pairs (as they have about the same heat stresses for close proximity and the second may fail shortly after the first). 2.4L solenoids should not be cleaned (in other engines that might be a viable fix). Several people on forums state that internal wires fail from heat and that failure can be intermittent (heat & vibration could connect or disconnect the broken internal wires); the 2.4L solenoid connectors look pretty wimpy. Sometimes a code like p0010 will pop us, but not always.
Note that changing the accessory belt is expensive because it requires a special tool and takes some time; that was a good bonus service. And it was close to required changing.
OBD-II Trouble Code: P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
Detailed information on troubleshooting and repairing a p0010 check engine light code which refers to a camshaft position actuator circuit. Also includes links to relevant forum topics on the code.
www.obd-codes.com
