Hi All,
Can someone share wiring diagram for thermostat harness?
Thermostat has only two wires connector. One wire is easy to check to the ground, but second wire requires a diagram to find another end.
Issue I am troubleshooting: after thermostat replacement I am getting new code P0598 for Thermostat Heater Control Circuit Low, engine overheating and smoking.
Thermostat resistance is the same as old original thermostat ~16 Ohm.
