2017 Buick regal not starting after changing battery
ejuszczak22
2017 Buick regal 2.0 l
Hi my Buick regal battery went out on me at the store and I had to jump it to make it home, the battery was leaking acid and corroded so I bought a new battery and changed it out, after I changed the battery and turned the key it would make a single click but not start at all. I ended up changing the starter and putting everything back together and the same symptoms are occuring, what could this be?
A bad battery. Have the store load test it.
I was able to find the issue, one of my fuses on the positive side of the batter, the fuse block, was blown. Also there was a burnt electrical piece on my engine bay fuse panel so I will be replacing both.
