The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
No, I've had this car for 5 years. Last month I took a eleven hour trip to Ohio and check engine light came on, but went out while there. On my way back to Georgia the check engine light came on again. I was scheduled to get my brakes replaced the weekend I got back and was going to a diagnostic test ran, but the light went out on the way to the repair shop. About a day after getting my brakes done is when I first noticed the 3 keys programmed message. I didn't see the message again for about 2 weeks. Yesterday my car had a hesitation when cranking like it wasn't going to start, but today it didn't start. I did some research and found that it could be the key fob, so I tried my other key and it hesitated, but did start. Thanks for any help you can share.Did you just buy this car?
Are you programming a new key fob?
Did this message appear in response to something you did? I ask because I recently programmed a new fob for my 2013. That process requires, among other steps, using the "hard key" to unlock the drivers side door and 5 presses of the "start" button (my car has PEPS). Upon executing these steps, the message "x keys programmed" appears. Then you proceed to execute additional steps to add a new fob.As for the 3 keys programmed message, I will monitor it to see if it continues to come back. Thanks again.
No, this appeared after having some work done on my car. Whether someone at that shop did something, I'm not aware.Did this message appear in response to something you did? I ask because I recently programmed a new fob for my 2013. That process requires, among other steps, using the "hard key" to unlock the drivers side door and 5 presses of the "start" button (my car has PEPS). Upon executing these steps, the message "x keys programmed" appears. Then you proceed to execute additional steps to add a new fob.
You can't really "delete" a fob, but you can "start over" and program the system to accept only the fobs you have, effectively deleting fobs you don't have. On a 2013, you can do this yourself (see the manual) or you could take it to the dealer. The process is a bit tricky, so if you're nervous about it, I'd recommend taking it to the dealer. It doesn't involve buying a new fob, just programming the existing ones
Ah, well, as far as I know (I'm no expert), this message should not appear unprompted. I agree with others who've responded here. Ask the person who did the work what he/she did, and, depending on the response, take the car to a dealer and ask them to program the system to accept only the fobs you have in your possession.No, this appeared after having some work done on my car. Whether someone at that shop did something, I'm not aware.
