I've not seen one diagram to cover all the modules as they are scattered through out the entire car, and to post individual links would take forever. This is a list of the modules i've found for 95-96,
95
Accessory Delay Module, Alarm Module, Relay Module, Power Mirror Control Module, Power Seat Control Module,
Sunroof\Moonroof Module, Electronic Brake Control Module, Traction Control Module, Oil Level Warning Indicator Control Module, HVAC Control Module, Audible Warning Device Control Module, Panel Illumination Control Module, Exterior Lighting Module, Headlamp Control Module, Interior Lighting Module, Lamp Control Module, Powertrain Control Module, Ignition Control Module, Air Bag control Module (Also referred to as Sensing and Diagnostic Module), Suspension Control Module, Power Window Control Module (Express Down Window Module), Wiper Control Module
96
Accessory Delay Module, Alarm Module, Central Control Module, Emergency Contact Module, Keyless Entry Module, Relay Module, Power Mirror Control Module, Power Seat Control Module, Seat Temperature Control Module, Sunroof\Moonroof Module, Electronic Brake Control Module, Traction Control Module, Oil Level Warning Indicator Control Module, HVAC Control Module, Audible Warning Device Control Module, Panel Illumination Control Module, Exterior Lighting Module, Headlamp Control Module, Interior Lighting Module, Lamp Control Module, Powertrain Control Module, Ignition Control Module, Airbag Control Module (SDM), Computer Command Ride Module, Power Window Module (Express down window Module), Wiper Control Module
a word of caution, I don't know that this a complete list, some of the modules may have more than one module associated with it. I do think some of these are grouped into one module as I have a 96 and have replaced the MALL module (multi-function alarm lock lighting), doing a google search of the numbers showed it listed as a BCM. and neither bcm or mall module where listed in the above list, but you can google search or parts search all the items in the list and find results.
