I have found numorus Post about heaters not working on the buick regals. Some nice answers also. However mine is just a little bit different.
Help please if you can. Thanks in advance.
My 2003 Buick Regal has a automatic control. just lately I get in the car and the heater blower won't come on on any of the speeds. I can drive for awhile and so far after a mile or 2 it will come on. It works fine from then on.
I also pulled a scan on it and pulled a P0128 code. Has to do maybe with thermostat and antifreeze being below thermostat I think is what it said.
So Question is, Where do I start to find the problem. It has only done this twice but it is giving me a warning I think. I will probably pull the Thermostat tommorrow and replace it. (156,000 miles). Could this possible fix the fan blower also??
I also seen where one guy had a new control in his garage but stated he had soldered his and didn't use the new one. Is it hard to get the control out and will I see where it needs soldered if I take it out.
Thanks so much for any input.
Dad
Dad
