thechair95
- May 18, 2015
- Buick
Hi, my RM has a weird air conditioning problem. I wanted to convert it to R134 so I bought the fittings and evacuated the system. It needed a charge anyway. I went to put in the R134 and there was like a breathing noise after the compressor clicked off. It sounded like a leak.
So I replaced the the AC compressor and I found that the compressor oil leaked out because it was all over the brackets. I thought: oh, I got it fixed.
I put a new compressor on and the freon didn't want to be sucked in on the low pressure side. The hose looking wet after I detached it from the fitting. I know I'm not supposed to do this, but I attached it to the high pressure side just to see if it'd go in.
A freon can went in, but the ac doesn't blow cold. The pipes coming from the condenser are quite cold to the touch and water can be seen leaving the evaporator (condensation).
Could it be a blockage in the system? Could the dryer be full of crap and that's why the freon won't go in? Any thoughts?
I don't have the money to go to an AC specialist, and I don't have any gauges to measure pressure.
