ABs light was on intermittently, now on steady
bobbo
2008 Lucerne CXL, 2005 LeSabre Custom
'08 Lucerne ABS light was on and off periodically for months. Now it is on steady. I checked each wheel with a voltmeter and got a reading when I spun the wheel. I want to check continuity from each wheel to the ABS controller, and check for anything else that would be causing this problem. Anyone have a wiring diagram, trouble shooting information, etc.? Any help is appreciated. Thanks!
A scanner would be the best option to consider as it would identify which hub is the suspect.
