Ac pressure switch
automan47
2004 park ave
I found the ac high pressure switch but cannot find the low pressure it’s not on the accumulator could it be under the dash. It’s a 2004 park ave thanks
The control is built into the compressor called “compressor control valve” It's not serviceable unless you drain the system and some models also remove the compressor.
Ok thanks
I think I’ll just replace the compressor and get it over with. For what the control valve cost and the labor iam better off time wise
Thanks
Thanks
Thanks
Iam going to have someone run some checks before I replace the I have never had ac do this before. As I said when you first start it ac blows ice cold and you can run allday but as soon as you shut the ac off it will not restart for at least 15 minutes and sometimes longer before compressor kicks in and I have checked every breaker and fuse, even removed the ac control panel and checked the soldering on all circuits and still the same problem.
I do want to thank everyone for their help and if and when I find out what it is I’ll be sure to let everyone know
