Air Pressure Sensor
liorsgs
lior1212
Hi I have a Buick La Crosse and I had a tire monitor system lamp on I was told that an air pressure sensor needs to be replaced. I ordered such a set and replaced I was able to re-learn the sensors but after a half hour drive it loses contact with the sensor again... I also tested a good battery and yes I put another sensor from another company and still the same problem someone encountered?
Has anybody scanned the TPMS to determine which wheel is causing the issue?
I replaced the sensor it worked out for about half an hour and then it came back the fault
don't have fault number write me monitor system tire
That did not translate correctly. You need a scan tool for the TPMS. There are two parts, the transmitter in the tire valve and the receiver in the car.
