Air stuck on defrosters
Synna
Park ave. Surpercharged ultra
I have a 99 park ave. Supercharger ultra and it’s been stuck on the top air vents since I got it. I’ve tried searching the problem and only finding things for the LeSabre. Is there a way to fix it?
Typical blend door failure!
I had a 1998 Olds 88 that would always blow through the defroster vents. I had a vacuum leak right before the vacuum line goes through the firewall to the HVAC unit. A one and a half inch piece of vacuum hose solved the problem.
I don't remember if the '99 was vacuum controlled actuators, or electrical servo controlled. Maybe someone here can help clarify.
