avtechwx3
- Jun 22, 2018
- 1992 buick lesabre and 2000 buick park avenue
2000 Buick Park Avenue non supercharged. Have voltage drop occasionally, went through everything in charging system, checked out fine. Alternator is 2 years old AC Delco, correct voltage of 14.5 or so at the battery and the alt. post. Alt. ground is good as is the heavy gauge connections to the battery. I noticed the connector plug on the side of the unit is in bad shape, needs the pigtail spliced in. Listed as 4 pin connector but I see only 2 wires. Did Buick make different connector configurations? Thank You.
