steppjohn
- Oct 14, 2010
- Buick
Hi
Problem with 95 Lesabre Liminted climate control system.
Just noticed that the heat-a/c blower motor does not blow on either heat or ac. Some heat trickles out of the system so I am assuming that the problem is just the motor.
I checked under the hood and see what I assume to be is the motor,, Delco part no 5049767,, on the firewall just behind the engine. I disconnected its electrical plug and tested for power. The plug is powered up, (and the motor is not running)..
I would assume that I should get blower action immediately especially if the car is already warm and operating.
Any thought? Do I just get a motor or there there more to the system to consider.?
Also, I notice a rubber hose-like connection from the bottom of the motor housing to the firewall. Looks kinda like an A/c drip connection. What would that be on a motor..?
Thanks John
Thanks John
