Benzadmiral
- Jan 8, 2014
- 2016 Buick LaCrosse 3.6 Premium
The 3800 engine you can change the PCV valve on. It's a little hard to explain how to find it, but it's easy -- I did it at least twice on my 3800-powered Park Avenue. My advice is to use the OEM part; I bought an aftermarket PCV valve and it rattled in the housing. OEM fit perfectly. Some weight or brands of oil may be consumed more easily: The PA gulped Castrol Edge 5W-30, but was much better on almost all the other conventional oils I tried over the years.
The 2.4 L Ecotec is another animal entirely. Mine (a 2011 Regal) began using oil quite a bit, and I found the PCV valve is integral to the manifold and not easily changed by the owner.
