G13
- Aug 11, 2023
- Present 2014 verano -, Past 2020 Encore, 2000 Regal
Ok if you found this then this is what you've been looking for!! After 3 days of off and on searching I never found the answer so i did what i was trying to avoid and took it apart to find the answer... Finally, are you ready? My 2014 Buick verano Bas3 mod without amp or rear deck speakers only door speakers..... The rear door speaker wires are... LR- (Green+-'Green/Blk-) and RR-`(White+/Blck-) I looked everywhere no one was saying anything definitive the info just isnt out there like its got some protection on it or something so i had to post this. I still dont know what or where or which wires are on the head unit when you get it apart its like being on a spaceship with these plugs i haven't experienced before but you can find those 4 wires in the harness if your wanting to add a RCA adapter oh and its not that hard to acesss the head unit getting that peice around the gearshift is the hardest part and you can leave it just put it in N or Drive twist it and leave it i would put the rca in there be the raido or underneath unless you have the bose system with rear deck speakers ok good luck . Make it Happen your the Captain
