- Mar 28, 2005
The "Melted" Mystery: This is the #1 "mystery failure" on the Buick Lucerne (and Cadillac DTS).
The Symptoms:
The car cranks but will not start.
You do not hear the fuel pump "hum" when you turn the key to ON.
You smell a distinct "burning plastic" odor inside the cabin, specifically near the back seat.
The Cause (It's not just the relay!): The fuel pump relay is located in the Rear Fuse Block under the rear passenger seat.
The Design Flaw: GM designed the metal frame of the rear seat bottom too low. When passengers sit in the back, the metal seat frame physically presses down on the fuel pump relay.
The Result: This pressure wiggles the relay while you drive, creating electrical resistance. Resistance creates heat. Eventually, the relay gets so hot it melts the plastic fuse block around it, breaking the connection.
The Inspection:
Lift the bottom cushion of the rear seat (pull up firmly on the front edge to pop the clips).
Locate the black fuse box on the passenger side.
Remove the plastic cover.
Pull the Fuel Pump Relay (Check the diagram on the lid).
Look closely: Is the plastic around the pin slots melted, brown, or black? Is the relay leg scorched?
The Fixes:
Option A: The "Official" Fix (Expensive)
Replace the entire fuse block (GM Part # varies by year, approx $300-$500).
CRITICAL STEP: You MUST use a hacksaw or grinder to trim the metal bracket on the bottom of the seat cushion that sits above the relay. If you don't do this, the seat will melt your new fuse box in 6 months.
Option B: The "Bypass" (Smart & Cheap)
You don't need a whole new fuse box. You just need to move that one circuit.
Buy a "Fuel Pump Relay Relocation Kit" (vendors like Renegade Solutions make a plug-and-play one).
These kits plug into the melted slot but move the actual relay to an external heavy-duty holder that hangs off to the side, safe from the seat frame.
Does anyone have photos of a melted fuse box they can share?
The Symptoms:
The Inspection:
The Fixes:
