Can i get better gas mileage on a 2007 buick lacrosse
cturner41314
I have a 2007 Buick lacrosse with 3.8 engine. I am just getting about 21 or 22 miles to the gallon. I had older cars with 3.8 engine and got 32 miles to the gallon on the open road. Can you change the computer on this car and get better gas mileage?
This is an interesting question. I also have a 2007 Allure (LaCrosse). It doesn't get very good gas mileage either. It's OK, but I thought it would do better. My wife has a 2003 LeSabre and when I drive it to work it always gets better mileage than my car. When I bought the LaCrosse I figured it would be the same as the LeSabre but for some reason it's not. Same driver, same outside temperature, all conditions the same and the LeSabre is always better. It is what it is, I guess.
what is the maintenance history of the vehicle, in particular have you checked the air filter? Is it overdue for spark plugs? Do you maintain the correct cold tire air pressure? are you doing mainly highway driving or local driving? The EPA rating is 17 City, 27 Highway, and 21 Combined.
Adding on to MelsRegal's suggestions - how is the thermostat in the car? My (used) 2005 Lacrosse was getting lower mileage than a '95 with the 3800 (Series II) engine. It wasn't until winter that I discovered that the heater was so-so and I mentioned it to my mechanic. One new thermostat and coolant flush later the mileage was very close to the '95 on the highway - 28 to 29. Around town it would get 23 or so, and a bit less in cold weather.
With the old thermostat, the temp gauge would go up to about 3/8's on the scale - now its around 7/16 - if you can visualize that.
Oh, one other thing - if you do get a thermostat, you may need to have the heater core back flushed as well. After having that done, the car is really toasty in Minnesota winters.
My car has 47000 miles on it. I have check all I know to check. I have not checked the screen in the intake. I have had century and Lesabre both and got good gas mile. I am not happy with this one.
If the car gets poor gas mileage and poor performance, you might have a problem with the cam sensor. One known problem is the sensor magnet coming out of the cam. You pull the sensor, and rotate the engine until you can see the cam magnet. What you may find is the magnet is missing. the plastic part that holds the magnet in the end of the cam has broken and the magnet has come out.
Replacement magnets are available from auto parts stores.
On your current tire's sidewall, what is the maximum inflation pressure? What pressure are you running in your tires?
I have not had problems with mine. It's a 2008. I will say that the all-city gas mileage is not great, around 20 to 22 mpg.
I had code P0128 occur and, rather than call for a new engine temperature sensor, it required a new thermostat. It only happened in the winter. The code is gone as a result of a great mechanic fixing it and gas mileage improved a little bit. The temp gauge was reading at 3/8 of the way up, or a little less. After the fix, it was reading a little more than 3/8 of the way up. I'm figuring it makes for a more complete fuel burn if it's running a tad hotter.
Mixed driving gets me 24 to 25 mpg. A highway jaunt where I vary the speed, down to the 55 and up to 70, and encounter some stop and go, gets me about 27 mpg. Just recently, I did some pure highway jaunts (basically open highway of at least 100 miles ... and gas station pump to gas station pump), set the cruise at about 65, and pulled in 31, 32, and 33 mpg. I was doing it to see how badly I needed a tune up now that 100,000 miles have finally rolled around. I will defer a little on this.
The low fuel mileage could be lots of things - tire pressure, an intermittent, hidden code, a less than clean throttle body, a faltering coil pack and/or plug wires, a worn out PCV valve, a loose vacuum hose, etc. All cheap enough fixes. Being diligent with easy stuff like oil changes, air filter changes, and fuel injector cleaner has kept mine running clean and economically. And always look under to hood to see what's askew. Next come the new plugs and plug wires for me.
There was also a batch - hopefully small - of Series III 3800 V6s that had some oil consumption issues, with a technical bulletin released, and I'd bet those didn't get the mileage that the tighter ones did.
Don't forget to check the precat o2 sensors. Even if there not throwing a code they're getting old and may not be reading the fuel ratio as well as when new.
See ya.
