brian doerner
- Sep 6, 2016
- Kitchener, Ontario, Canada
- 98 Buick Century
I am working on a 97 Buick Century with 100,500 kms on it. It's a good car no rust thru the body. The windshield wipers work good when they are turned on but when they are in intermittent mode they'll park at the 12 o'clock position. I found this video https://www.youtube.com/watch?v=e_TBkMTN42I and did everything mentioned - TWICE to make sure I did it right. I noticed the guy in the video turn the "locking mech" with his hand..well..Unless U were AHRNOLD U wudn't be doing that with this one. Had it in the vice and turned it with a big set of channel locks. and then the guy says tighten it it to so many many newton meters or use an inch torque wrench to tighten the screw - I don't have a torque wrench so I tightened it with a mini ratchet...oh and the little spring broke which holds the "parking arm" when in reverse. I still have the same prolm.
I have an ABS light on but it comes and goes. How do I find what causing it and fix it?
A mechanic says it needs new front pads and rotors - but the brakes feel better than my own car - what measurements do check to see if this guy is just trying to make $ or not?
How do I know when they need replacing?
Thanx in advance.
Thanx in advance.
