steppjohn
- Oct 14, 2010
- Buick
Hi,
I just had my 95 LeSabre looked at for the mysterious "occasional engine shut down problem." that has been talked of a few times here.
I was thinking maybe I would get the Crank Sensor changed since that seemed to be a possible problem item.?.
I had no CEL light suggesting anything (I thought)
But guess what, The mechanic pulled codes and found a code for the TPS. He said the TPS was not sending out a signal at all. Did not know I had a TPS problem. The car seemed to drive and perform fine, except for the occasional intermittant engine shut down. Is this likely for a TPS to fail and not be noticed?
I had him change the TPS and I looked more closely at my test lights that glow on start up. Guess what, The CEL light did not light up!! I have no idea how long it might have been "out."
So I gotta fix that.
Any advice from you guys? I have in the past taken off the top of the dash that accesses the area where the warning lights are, but I never did anything to the lights and I don't recall what they even look like.
Thought I would ask before I get into this, Is it easy?, do you just change a bulb?, or is it a more difficult thing to do?
John
John
