Chimes won't stop on my 2003 lesabre
Outlaw3369
03 Lesabre
Hello everyone is there any way to delete all the chimes in my 2003 lesabre ? Thanks in advance!
Remove your factory radio and put in an aftermarket radio using a cheap harness adapter is one way to do it. I'm sure someone else knows of a less extreme way of getting rid of the warning chimes.
If your warning chimes won't stop what problem is it trying to alert you about?
The door latch is telling the car one of your doors is ajar. Try opening and re-closing each door and see if the dinging stops. If not, it could be that your latch -- with the door switch built in -- has gone bad.
You can’t really “delete” them without messing with the wiring, but an easy fix a lot of folks try is pulling the little chime module under the dash. Just be careful though, because it also handles warnings you might actually want to hear (like low fuel or key in ignition). Another option is to put a small piece of tape over the speaker hole on the module to muffle it instead of killing it completely.
No such thing as a chime module from the factory. The chimes are generated by the radio and come through the driver's door speaker.
Maybe you're thinking of the previous generation '92 to '99.
