manlion
- Aug 23, 2010
- Buick
1. Is the temperature sensor (in/by the water pump) controlling the temperature gage the same sensor that controls the EEC and HVAC "-24" reading?
2. I find info on a sensor located in/by the water pump(it is a thermasitor).
3. The one in the block is for the idiot light (it is just a switch).
According to this post about troble codes:
http://www.buickforums.com/forums/showthread.php?p=43614#post43614
Has this information been decoded?
According to Cory: (Page 1)
-24 is the WP.
According to one member (Thanatos), (Page 2)
"-08 is indeed at the WP. THe reading defaulted at 173* or something close, when unplugged".
According to (Electralt1) (page 2)
Used the HVAC method to read the codes on the LT1 i swapped into a 85 Electra estate. What i also observed is that -08 & -24 seem to be the same. One is fahrenheit and the other is celsius. Both readings seem to go up together when idling from cold start. Diagrams indicate that the tranny has a temp. feed to the PCM but one would expect the tranny to heat up at a delayed rate because no work is being done at that point and the thermostat has not opened.
As far as I know, there are two temp sensors on this LT1. The ECT sensor and the gauge temp sensor. Only one sends a signal to the ECM, the other sends its impedance to the dashboard gauge; there is no [COLOR=blue !important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][COLOR=blue !important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]cylinder [/FONT][COLOR=blue !important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]head[/FONT][/COLOR][/FONT][/COLOR][/COLOR] sensor communicating with the PCM. Later this week i will observe more thoroughly the HVAC info and maybe borrow a scanning tool.
-24 is the WP.
