twj815
- Feb 20, 2014
- 95 Regal and 96 LeSabre both 3.8
I have a 1995 Regal 3.8 V6.
The only way I can get a cooling fan to operate is to turn on the AC. The car over heats otherwise in stop and go driving. Only the driver side fan comes on with the AC on. I have swapped fan relays with no change. I have jumped across the contacts of the other fan's relay and that fan will operate. Both relays and fans are good. There has been no check engine light. This car has a 12 pin OBD1 connector.
Should both fans operate with the AC on? When the temperature gauge goes above normal, the car will eventually start running rough and will stall while idling. Then it can take up to 2 hours to get it to start again.
Is there anything else I should check before ordering a new PCM?
