Crank no start strong fuel pressure
SerDav
Lasabre
Hi I need some help my 2001 Buick lasabre cranks over no engine codes for reference has fuel pressure but won’t start replaced icm and crank sensor about to change the cam sensor am I missing something please help
Welcome.
What is the vehicle history and is all maintenance up to date?
Why did you replace the ICM and crankshaft senor?
Do you check for spark?
Are there any codes?
Unless you checked fuel pressure with a gauge you can't be sure it's correct.
A bad cam sensor would illuminate your SES light.
Try disconnecting the MAF sensor.
Do you have a code reader?
