CottonPicker
- Jul 13, 2023
- S.E. USA
- 2005 Buick Lesabre
This occurs cold start only. Miles 121,242. First time @ 116,059, then 116,559, 116839, 117497, 119,087, 119.020, 120,900, miles. No crank learn - No scan tool. No CEL/SES
Delphi Cam and crank sensors @ 94,xxx. Wiring Clean and terminal ends tight using oem male with drag test. Engine clean.
New AC Delco DIS module, with file flat base Grds cleaned and thermal paste @ 110,xxx miles. Injector sent out @ 110,000 for clean and flow - no leaks. Reman Delco starter @ aprox 85,xxx
If coolant or fuel was entering any cyl I believe there should be smoke or a smell out of tail pipe. THERE IS NONE. No raw fuel, or sweet coolant. I move to the rear of the car very fast to see/smell.
When starter stops, I immediately release the key to run, two seconds I reengage the starter and it starts normal, No misfire, engine sputter, no movement in engine bay after. Fuel reg vac hose NOT wet.
No scan tool. Went to local shop asking but this occurs so intermittent it would cost $$ to watch.
I am about to buy a Chinese Tech-2 Plus already ordered A/C Delco / GM Crank and cam sensor, cam magnet, t-chain set, WP ect to replace.
PCM OEM. Have Delco replacement ready.
(By the way. For 3.8L T-chain set Cloyes made in Taiwan. Melling USA)
Your thoughts and suggestions.
PS. When the engine cranks I hear each time the cylinders reach a compression stroke and count them. Normally, not occurring, the comp strokes hat 3 to 5 time before run cycle. When failure occurs or CRANK TO RUN ERROR, the compression strokes hit 2 or 3, then the starter stops and the engine won't turn over. I do not hold the key and allow the starter to remain engaged. Each time I release the key and restart as described.
