Driver Door Module or Driver Window Switch?
eckeith
2002 Park Avenue
No power windows at all 4 doors.
No power door locks at both front doors.
Power window lock-out button does not light whether pressed or not.
Interior lights do not turn on when doors open. They do turn on when the key is removed from the ignition or turned on by the dash switch.
Radio does not turn off when the door is opened. RAP times out normally.
DDM fuse checks OK.
WDO circuit breaker checks OK.
G200 (ground) clean and tight.
12V on yellow wire on Driver window switch so I assume that means the Driver Door Module has 12V.
I haven't removed the door panel yet.
Any ideas?
Thanks!
I didn't have same exact symptoms as you, but I thought my problem was the door module too. Turns out it was the switch block. Neither one was too expensive. I'd pick one, then go to the next one.
eckeith,
Did you find any solution to this? My situation seems identical to yours and the cause hasn't been found. Plus, my a/c leaks and that has made it all almost impossible to live with. I, at least need to be able to put a window down. Please post even if no solution was found. I really need to know.
