Electrical issue
cstevens1066
Verano
I have a 2015 Verano and a couple days ago I started the car and my dash gauges and radio stopped working . My tach , speed and odometer , gas and temp needles don't operate. Infotainment screen is black and does not operate . The car runs and is drivable and I do have headlights , high beams , brake lights and turn signals (of course high beam and turn signals symbols do not illuminate on dash) . I've checked all the fuses and none are blown . I'm thinking maybe a ground connection and wondered if anyone has dealt with this type of issue and could point me in the direction to what common ground to check . Thank you for your time and Merry Christmas !
I assume you know you have 3 fuse boxes. Did you check all of the boxes?
Because I am finding no blown fuses , Hence the reason I believe it to be a ground connection issue , but exactly which ground should I be focusing on is the question
