vadonkey
- Nov 23, 2016
- Buick
The Encore doesn't sell a ton of vehicles, so I looked for other GM models that uses the same drivetrain to get a feel for reliability longterm and higher volume. The Cruze sells a ton more than Trax/Encore so I think it's a good guide to use
just google GM 1.4 Ecotec engine. Click the links that relate to the Chevy Cruze for a lot more info regarding the reliability of the 1.4L Ecotec engine
There appears to be 2 glaring issues that plague the the 1.4L engine (not the sport model, that uses a different engine)
1) PCV failure- A check valve in the PCV system fails requiring the intake or valve cover gasket to be replaced...You will get a check engine light when it has failed and your car will run rough-Mine has been replaced.
2) Water pump failures- A chirp/squeak under the hood and coolant loss..... I have this going on right now, but my dealer is just tops off the coolant saying "it's evaporating". Coolant doesn't evaporate!- I'll go to a different dealer
Everything else seems pretty well put together. My Encore is a 2014 with 43K miles. Bumper to Bumper ends in May
