AuctionLucerne2006
- Sep 29, 2023
- Lucerne CXL
I've have a 06 Lucerne CXL 3.8 series 3 that I was seeing an active leak of coolant from the area of the notorious plastic elbows/water pump/lower radiator arm area. One of the plastic elbows had already been replaced by previous owner, water pump looks replaced as well. Checked lower rad arm no cracks. So I am thinking that O ring on the newer SS arm that was replaced went bad. Anyways, as I was putting everything back in the ground wire broke and then the wire harness was broken as I was putting things back together. So I have to either buy the new part from Dorman pt no. 645-688, albeit Dorman's website says this part doesn't match my vehicle, and this seems to be the only parts dealer that offers this discontinued part which also matches what I took out of my car, from GM or buy used from junkyard or try to splice back together, which I am leaning towards. Does anyone else know where I can find this specific part. TIA
