Front and Rear Strut Torque Specs 2008 Allure CX 3.8
PJC
Allure/Lacrosse
Just looking for front and rear strut torque specs for a 2008 Allure (Lacrosse) CX. Thx
Front
  • install the strut upper mounting nut and tighten to 33 ft. lbs. (45 Nm).
  • Install the strut lower bolts and nuts.
  • Align the strut to the marks on the knuckle. Tighten the strut lower bolts/nuts to 63 ft. lbs. (85 Nm), plus 60°.
REAR
Tighten the strut to body mount nuts to 45 N·m (33 lb ft).
Tighten the strut to knuckle bolts and nuts to 120 N·m (89 lb ft).
Notice
The knuckle must be retained after the strut-to-knuckle bolts have been removed. Failure to observe this may cause ball joint and/or wheel drive shaft damage.
Free Chilton Online Repair Manual
