Front interior passenger door handle replacement 2015 Buick Regal
jayred
2015 Buick Regal T 2.0
Hello,
I just wanted to ask how can i find an interior passenger door handle with bezzle and hole for lock/unlock buttons?
I am trying to replace the interior door handle since the plastic on the surface is peeling and I don't want my passengers getitng their fingers cut by opening the door.
Anything will help!
First, you should research to see how to take off and put on that interior door handle. Hopefully it isn't part of the door panel, which would make things very tough.
As for the part itself, I think you should go to a local dealer to try to get the correct part number, as well as the price they're gonna charge. Take the part number, look it up on Google, and then see if you can find the correct part for less than the dealer is charging. I looked at some of the sites that I use when looking for parts, and I had a hard time finding that specific door handle with the holes needed for the buttons. Even just a generic Google search showed me a lot of door handles that looked correct, but weren't.
If you can't find them online, I'd suggest visiting a local junkyard and/or a Pull-A-Part (after checking their inventory first) and see if you're able to take one off. If not, then you're at the mercy of the dealer you visited.
Someone correct me if I'm wrong.
