Re: Fuel Gauge always reads "FULL"
There is a float attached to the fuel pump that sends a message to the gage to tell how much fuel is in the tank. The contacts on that float wear out, and the only way to repair it is to replace it. On the 2000 and up Lesabres, there is an access port in the trunk on the right side near the front of the trunk for replacing the pump. On Lesabres before 2000, the gas tank must be removed. My 01 Lesabre was doing that for three years or more. When I fill up, I reset the trip odometer, and refill around 300 miles. There is a 16 gallon tank, and I average about 25 MPG, so 300 to 350 is safe, I have never run out of gas. Fuel pumps are expensive, and there is a kit to replace the sending unit for around $50. I am going with resetting the trip odometer until the pump fails. Do what you feel will solve your problem, and good luck.
- - - Updated - - -
- - - Updated - - -
What is wrong with this web site? Took almost 3 minutes to post, and it double posted.
- - - Updated - - -
