Fuse for Dash and Stereo Lights / 94 RMW
SKV
Hi Comrades!
I plugged the radiator fans connectors together with the engine running and I suppose it knocked out lights on the dashboard and stereo of my 94 RM Wagon last night. Which fuse might been affected by this? (I replaced a radiator (which turned out to be quite easy even for the newbie like me) and forgot to replug the fans - bummer.)
On another topic, my other 96 RM Ltd Wagon periodically makes this kinda roaring/grinding sound coming from the driver side even when the car is off and cold. What can it be and is it bad? 🙂
Thanks a lot as always for your infinite wisdom.
The fuses that's easy, go the fuse and just look for a bad fuse. There is a chart on the backside of the cover that will help you. Worse comes to worse, pull one out at a time and look at it.
Now for the noise, even when the car is off, I am guessing it is the air compressor for the automatic level control. It is on the driver's side under the front bumper. It is normal to hear that occasionally.
Tom C.
